I have a dvd-r with video burned to it already. It plays in the dvd-player & everything, but the picture is too dark. I no longer have the original vhs, so I can't simply re-capture it & adjust the brightness like I normally would. Can I rip the dvd-r & adjust the brightness? If so, what tool can I use? A couple tools I already have, but couldn't figure a way to do it with, are the following...
InterVideo WinDVD Creator
TMPGEnc DVD Author 1.6
Ulead VideoStudio 7 SE DVD
...thank you in advance, as always.![]()
-Chauncey
Can't you import dvds in videostudio? Or else use vob2mpg on the DVD and import the mpg in videostudio.
If there's an option for it, I'm not seeing it...which means I could just be missing it.Originally Posted by Baldrick-Chauncey
You could run it through DVDRebuilder, which of course means re-encoding. Add a line of Avisynth script in the filter editor and save. For example:
Levels(0,1.3,255,0,255)
#Corrects gamma for display in a brighter environment.
Or this:
Tweak(hue=0,sat=1,bright=10,cont=1)
#Brighten: goes from (-)255.0 to (+)255.0, default 0.0
Good luck.
[EDIT] The scripts above just brighten everything up a bit. With Tweak you can also adjust the color saturation, hue, contrast. For more, look here:
http://avisynth.org/mediawiki/TweakPull! Bang! Darn! -
Separate from recoding, you have playback brightness/contrast controls in software and some hardware DVD players plus of course display controls.
The reason you try to get it right before encoding is to avoid using these controls.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
brighten only a portion of a video?
By magnumpy in forum EditingReplies: 1Last Post: 23rd Dec 2011, 01:00 -
need to brighten a video
By kevykat in forum RestorationReplies: 6Last Post: 13th May 2011, 11:38 -
Can you please brighten up my video ^__^
By Jenniilovekpop in forum RestorationReplies: 34Last Post: 28th Nov 2010, 00:30 -
Brighten a video
By Clarky_man in forum Video ConversionReplies: 40Last Post: 13th Feb 2010, 06:37 -
How do I brighten dark video (mpg) files before burning to dvd?
By denise4gb in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 23:17
