I am receiving this message when I try to extract from a DVD (Which is not protected)
Can you let me know what I need to do to get past this and be able to use the ffmpegX software?
I installed all of the binaries.....help!
Thanks!
CrossEyedAlien
Just fyi, ffmpegx takes a rationally conservative approach to interpreting the DMCA. By prohibiting direct DVD input, ffmpegx evades accusations that its primary purpose is to copy DVDs. This prohibition is an inconvenience, of course, but it keeps Major well out of jail.
There are tools by authors who have chosen to take a riskier approach, but on the mac, there aren't any with the range of functionality offered by ffmpegx. For example, if you only need to convert into Divx/XviD, D-Vision3 will allow direct DVD input. It contains an internal ripping engine, although it isn't as capable as the newest dedicated ripping tools. But for your case, where the DVD itself has no CSS, it will work directly from your DVD, without the additional time/space consumed by copying to the HD first.
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 13:40 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 17:22 -
Trying to locate a device in Device Manager
By alegator in forum ComputerReplies: 2Last Post: 13th May 2009, 10:53 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59
