    Dec 2007
    Netherlands
    Hi,
    I'm agonizing for a week now trying to find a way to add subtitles to a film I've made on Studio 9.
    I also have the Subtitle workshop program which seemed promising but I just don't know how to combine between the two.
    Any idea's???
    I need this film finished this weekend!!!
    Thanks!
    Do you want permanent/burnt in subtitles in the video? THen I don't think you can use Studio 9. If you have already edited with studio 9 then I would add use autogk, open the edited avi, add the subtitle file you made with subtitle workshop and make a avi divx/xvid, see https://forum.videohelp.com/topic316471.html
    If you want switchable DVD subtitles use an authoring tool with such support like Tmpgenc DVD Author 3.
    Dec 2007
    Netherlands
    I do want a switchable option, because I need to translate it to 3 languages.
    Any tips? I thought dvd-lab pro should do it...?
  4. Member manusse's Avatar
    Jun 2006
    France
    You can use SubtitleCreator for that.
    First create your DVD with Studio. Then create your subtitles (srt format) using VisualSubSynch. Finally use SubtitleCreator to add your subs. Tools->DVD authoring wizard.
    Cheers
    Manusse
