  1. is there some freeware software available that will play a vcd on a cd-rom computer drive? (not dvd-rom) the vcds are on cd-r media.
    thanks
    gateway to the west
    okay pretty much any dvd playing software will play vcd. but,
    here is couple freeware vcd players:
    I-VCDP:
    http://www.i-on.net/ioneng/downloads/index.html
    Quick VCD:
    http://www.zdnet.com/downloads/stories/info/0,10615,73127,00.html
    have a good one
    gateway to the west
    by the way, vcd are on cd-r media not dvd-r media, unless of course you followed one of the guides here and burned it to dvd-r. But I'd say 99% of vcd are cd-r.
    both freeware programs above play vcd pretty well. Though my favourite
    is the I-VCDP program nice design and plays them very well.
    and if you use the zoom control on the player you can put the playing at full screen.
