Results 1 to 10 of 10
    Jun 2007
    South Africa
    does anyone know of a program or utility that can scan any movie file and report whether it is interlaced or progressive?
    Apr 2004
    Miskatonic U
    g-spot can do most formats.
    Read my blog here.
  3. Originally Posted by demonwarrior
    It's called your eyes. There are plenty that can tell you if it was encoded as progressive or interlaced (DGIndex, Bitrate Viewer, ReStream, etc), but the best way to tell if the source is interlaced (has the fine parallel horizontal black lines during movement) is still your eyes. Just play it in a player where you can pause and advance a frame at a time, and where you can turn off any deinterlacing filters so you can see the artifacts. Or open a basic unfiltered AviSynth script in VDub(Mod), scroll to a place with movement and advance a frame at a time.
    If you really want to try out an automatic interlace detector, then read this:
    http://avisynth.org/mediawiki/Interlace_detection
    But after reading it, you might change your mind.
    Jun 2007
    South Africa
    so what should i look for in Gspot to tell me whether it is interlaced or progressive?
    Oct 2005
    Use your eyes bro its very simple.
    Jun 2007
    South Africa
    well i dont have the time to watch each clip and movie
    Apr 2004
    Miskatonic U
    I think he was referring to the g-spot screen. There is a small indicator that lights up I/L if the clip has been encoded as interlaced. It's in the Pics/Frames/Fields section. It will also tell you whether it thinks it is Top or Bottom Field First. I can't vouch for it's accuracy.
    Read my blog here.
  8. both MeGui and AutoMKV has an interlace detector that can be runned stand alone, without encoding
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
    Jun 2007
    South Africa
    tx will give it a go
  10. Originally Posted by demonwarrior
    And that's going to be faster than taking a quick look at the video?
