I have this project im working on - but the source disk was pretty bad and i had to go thought a whole bunch of hoops to get anyhting - but i cant burn it with nero 7, i downloaded dvdrebuilder and see that only VTS_02 is listed - and get a "missing vts_1" message -- ive never had to do somethign as complcated as this - but is there a way to fool the tool or edit the image so that i can burn this to a disk? i tried also downloadign vobedit v.06 but havent had much luck am hoping someone can assist
the files of my proj are as follows:
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_0.VOB
VTS_02_0.BUP
VTS_02_0.IFO
VTS_02_1.VOB
VTS_02_2.VOB
VTS_02_3.VOB
VTS_02_4.VOB
VTS_02_5.VOB
VTS_02_6.VOB
Steve_77
Here are some options for you. None of them are optimal but ...
Do you know what is in VTS_01? and whether it is important for what you are trying?
You can use VOB2MPG to convert the VOBs you do have back to mpg file then reauthor with what you have left. Of course it will be missing the video and audio from VTS_01 and will lose a bit of quality along the way but not to much.
Referring to question 2 above, if VTS_01 is important, you may have to go back to the disc and play some more trying to recover those files. Of course, you could go back to the originator of the disc and see if re-creating is an option. But I am sure you already thought of that.
Lastly, as already mentioned there are other recovery tools and steps available. But that is back to the playing with the damaged disc.
Ed -
Load the VOBs you have in NeroVision and see what you have. You can merge them if you like. With a little luck Nero won't re-encode and you can then save/burn what you have.but i cant burn it with nero 7
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 12:06 -
Optiarc AD5170A 1.13 Wont burn 'disc at once' any ideas?
By surfmonkee in forum DVD & Blu-ray WritersReplies: 1Last Post: 17th Jan 2008, 11:44 -
Why won't my VTS_01 file work on windows movie maker?
By LITEONDVD in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2007, 11:13 -
Best image quality as possible for AVI videos...FFdshow filter.Any ideas???
By fgtan in forum Media Center PC / MediaCentersReplies: 0Last Post: 21st Jun 2007, 15:17
