Hi all
What would everyone say is the best tool for converting VOB files from NTSC into PAL format?
cheers
Daz
check the "How To" and "All guides" on the left, but search for DVD-to-DVD or NTSC-to-PAL conversion instead of VOB-to-VOB (thats kinda pointless IMHO)
I asked the same question some time ago.
I tried it and it is not worth the trouble as there are so many cheap to expensive DVD players that will play both NTSC and PAL to a PAL or NTSC TV
Just take the time to search and read a bit as the sticky Sticky: "How do i get my questions answered on these forums" at the top of this forum mentions
see Sticky at the top of Newbie Conversion
NTSC to PAL, PAL to NTSC framerate conversion?
Also if you search the forum NTSC into PAL there are tons of hits and tons of problems with jittery picture being one of the top problems.
Good Luck,
Joey
What is best way to convert vob files from pal to ntsc and vice versa?
By hibbs in forum Newbie / General discussionsReplies: 2Last Post: 14th Jan 2010, 19:41 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
Best way to convert NTSC .VOB --> PAL .VOB
By macuser1960 in forum ffmpegX general discussionReplies: 1Last Post: 9th Mar 2008, 16:43 -
.Vob, PAL to NTSC tool??
By i0r in forum Authoring (DVD)Replies: 6Last Post: 16th Dec 2007, 16:45
