I'll try to give a short overview on what I'm trying to do....
I'm backing up one of my favorite TV on DVD sets, but I'm also going through and editing each episode, taking out stuff that isn't funny, so the whole show flows better and is funnier. Anyway, I was planning on just making a basic menu for my backup, but now I'm pondering on something else....
Is there anyway to extract the video from a motion menu, and turn it into an .avi or .mpeg? I'd like to use the original main menu from my dvd, but I don't know how to get the video "out" of the menu. I hope this makes sense...
I'd appreciate any suggestions, so I can figure out if this is do-able or not...
Thanks!
Wouldn't it be simpler to take out the episode, edit it, then put it back in place of the original so the original menu can be used ?
If you really want to extract and mess with the motion menus, read my guide about how to do it, and you might change your mind about the project:
https://forum.videohelp.com/topic313743.html#1606732
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
extract dvd menu text & time
By msdiane in forum Newbie / General discussionsReplies: 0Last Post: 26th Oct 2008, 11:25 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Software suggestions for video clip or motion menu at the beginning of DVD?
By hitman3000 in forum Authoring (DVD)Replies: 2Last Post: 14th Mar 2008, 19:30
