Help someone please, I tape a party with video and audio my Problems is this I would like to have my audio Like that in movies or on TV instead of it sounding like it was done in a can Can anyone help PLEASE!!!!
A lot of work goes into TV and movies. For example foley sound, multiple microphones, soundboard audio (for music), multitrack mixing.
Darryl -
Start by using a separate microphone, and not the crappy one built into the camera. Get a good, uni-directional mic if you are hoping to pick up individuals speaking.Originally Posted by shaolin2006
As for what you have - there isn't a lot you can do. Play with the EQ settings in your audio editor to see if you can smooth it out some, but most likely the results will only be slight.Read my blog here.
Seeking help - convert/burn .OGG(audio only) 5.1 to DVD-Audio 5.1
By cinesimon in forum AudioReplies: 0Last Post: 18th Oct 2010, 19:28 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
Ripping Audio with ImTOO DVD Ripper Platinum 4 vs DVD Audio Extractor
By xtreme469 in forum AudioReplies: 0Last Post: 29th Sep 2007, 04:06
