I'm shooting in Pro Cinema Mode on a Panasonic PV-GS400 and using Vegas 7. I'm having no trouble exporting correctly and encoding to MPEG-2 for DVD. How can I encode the foorage to XviD properly. Using an all in one like Auto Gordian Knot the foorage is not handled properly and appears stretched vertically.
	It needs to be resized to square pixels, like 720 x 400 or 640 x 360 for instance...........you want a widescreen ratio of about 1.78:1. Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
	AutoGK can do it for you. Now I don't know in what DAR these videos are capped. Maybe racer-x will let us know. And I don't know what DAR AutoGK is assuming them to be. But evidently AutoGK is assuming the wrong DAR. Anyway, after opening the video (AVI? MPG?), go into the Hidden Options (CTRL-F9), and in the bottom left of the screen check the "Override Input AR" box and change it to whatever it's supposed to be. There are only 3 choices (4:3, 16:9, Original) and since one is already ticked (and wrong, evidently), you have 2 remaining choices.
 If no one comes along to tell you what the DAR of the source is, experiment with a couple of short videos to find out.
 http://www.autogk.me.uk/modules.php?name=TutorialEN#6
  HDV .m2t footage - Best quality conversion to MPEG4- method/toolsBy Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2012, 02:30
  Correct Project and Sequence Settings for footage from Panasonic TM300?By Bloodredthorn in forum EditingReplies: 0Last Post: 20th Jan 2012, 13:34
  getting video footage from a Panasonic HDC-SD600 to new iMacBy B Smithson in forum MacReplies: 8Last Post: 18th May 2011, 13:20
  footage from 5d Mark II mixed with XLII footageBy segan in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2010, 15:24
  Security Time Lapse Footage to DivX/XvidBy NightFire in forum Video ConversionReplies: 4Last Post: 2nd Feb 2010, 23:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
