I am thinking about buying a laptop, maybe an HP/Compaq. I think the drives only write at 8X.
Anyone have any experience with the ripping speed? Riplocked? (I am used to the relatively fast ripping speed on my desktop using a lite on)
Any info on HP or any other laptops will be appreciated.
8x is the fastest laptop DVD burner I am aware of.
Some laptop drives are riplocked - like LG - one of HPs vendors.
Firmware updates for laptop DVDs are few and far between, precluding MCSE rip-lock removal.
Laptop manufacturers are looking for low power consumption so slower drives are preferred.
If you want fast ripping and writing stick with a desktop. -
I wouldn't abuse my HP laptop DVD drive by ripping. I've already had to replace it once, and I don't use it that often.
You might be better off to pick up a external case and put in a DVD drive that works well for ripping and burning, and keep the internal drive for playback or the occasional burn.
I'll second what redwudz says.
Laptop DVD burners are more expensive and less durable than a desktop burner.
Buy a external USB case that takes 5.25" drives and hook it up via USB.
Any Laptops with ESATA out there?
By jbitakis in forum ComputerReplies: 5Last Post: 10th Nov 2011, 13:20 -
What is the difference between these two HP laptops?
By jyeh74 in forum ComputerReplies: 5Last Post: 14th Mar 2010, 17:35 -
trying to pick the best dvd software player for my "old" laptops
By cubajean10 in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2009, 20:01 -
Laptops with HD DVD...worth purchasing?
By jabol in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Mar 2008, 08:07 -
Laptops
By didikai in forum ComputerReplies: 9Last Post: 14th Jul 2007, 22:46
