We get this question a lot. Here are the steps to a successful installation:
1- Select your installation site carefully!!!: There must be a clear line of sight between the required satellites and the entire surface of the dish. The line of sight must be free from obstructions, such as trees, roof tiles etc.
2- It is very important to make sure the HH motor is fixed to a perfectly vertical mast. Time spent measuring this accurately will save you hours later on.
3- If the HH motor shaft is not at zero degrees (0 reference), you should get it back to zero degrees by connecting the receiver to the motor. The receiver must be ON for the HH Motor to move. It’s easier to do this before placing the H-H Motor onto the mast. Once you have done this, the HH Motor should then be disconnected from the receiver. HH Motors are usually set to zero degrees by default from the factory.
4- Fit the HH Motor onto the mast and do the nuts up finger tight.
5- Set the elevation angle for the motor. This angle should be equal to the latitude value of the installation location. Always use the Latitude scale on the motor. NOTE: Tighten all the coaxial cable connections only by hand. Using a wrench may over-tighten the connections, causing damage. Such damage is not covered by the Limited warranty.
6-Fit the dish on the H-H Motor shaft and tighten the nuts. The middle of the dish clamp must be lined up with the centre line on the H-H Motor arm. The LNBF arm, dish clamp, HH Motor, and mast must all be on the same straight line facing TRUE SOUTH.
Ebay link removed.
You are asked to contact the webmaster and get permission before you attempt to post solicitations or advertising.
Results 1 to 1 of 1
System.UnauthorizedAccessException error after WinXP SP3 install
By scoop46 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 20th Oct 2008, 10:03 -
Old Satellite system
By MadDog_Smith in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jul 2008, 15:51 -
Capturing VHS-C tapes. Get Motorized adapter or Non-Motorized?
By Tekken in forum Capturing and VCRReplies: 5Last Post: 14th Jun 2007, 17:51 -
How can I install PPro2 on system that doesn't support SSE2?
By Sean_ve99 in forum EditingReplies: 1Last Post: 26th May 2007, 08:33 -
DIRECTV launches Sat-Go portable satellite TV system
By BJ_M in forum DVB / IPTVReplies: 0Last Post: 4th May 2007, 09:15
