Originally Posted by ilovevcdhttp://apextechnology.co.uk/data-recovery-cd-dvd-floppy-photos-files-uk.aspEmpty or Zero 0 Bytes shown on CD DVD
Sometimes a CD-RW or DVD-RW disk will only show as being empty or Zero 0 bytes capacity. No Files or folder shown even though you can see the burn marks on the disk. We can recover your Video, Photos and Data Files from such Disks.
You need to take your fingers out of your ears. Nothing is infallible. I have software that can copy just about anything. It can recover data from severely mangled file systems.
Closed Thread
Results 151 to 180 of 214
Believing yourself to be secure only takes one cracker to dispel your belief.
Jesus H., and so on.
Yes, protection on any DVD is possible. But as everyone here and their dog has tried to explain to you in more ways than I can count, defeating that protection has proven not only possible, but piss easy.
Even if ISOBuster mistakes your VOB files for being zero bytes in length, that does not mean every other ripping program that comes into existence will make the same mistake. And if they really were empty files, your disc would be a coaster.
To echo Dv8ted2, if there are programs that can recover files from severely mangled file systems, you have two chances of preventing a concerted user from doing the same with your DVD. None, and fukk all."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Dv8ted2 wrote
"Nothing is infallible. I have software that can copy just about anything."
I know that 100% protection is inpossible, and Hollywood knows that too.
But they use it anyway, just to stop as many as possible even, even risking the compability.
And i have the same goal.
Nilfennasion wrote
"Even if ISOBuster mistakes your VOB files for being zero bytes in length,"
If you create a file on your harddisk that is empty, the properties says 0bytes. Or has the computer misstaken the filesize too.
All copy and ripping software i tried have not been able to crack the prot_dvd
Again, if the file is playable, it has to contain data. There is no way around it.
Now, I have to ask because this has been bugging me for a long time, but are you a Scientologist? Because seriously, you sound like one with the way you ignore the facts that are being told to you and invent your own."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
On the computer you can access any part of the harddisk by telling the disc-controller to jump to
LBA 2000, then you can read the data in that sector.
In the same way you can tell the dvd-player to jump to LBA 295, then you can read the data in that sector and play it.
This is sector based playback.
We are more realistic and know that sticking your fingers in your ears does not work. What you fail to realize is that the data must be decrypted on the other end for it to be playable. This has to occur or you have produced something that noone will want.Originally Posted by videobreadBelieving yourself to be secure only takes one cracker to dispel your belief.
Nilfennasion wrote
"Again, if the file is playable, it has to contain data. There is no way around it."
No, the harddisc-controller can access the harddisk whitout any sort of filesystem, BUT no filesystem can access the hard-disc without a disc-controller.
So if you access a disc or dvd this way, you can throw the filesystem down the toilet.
Just tell the controller to go a certain sector, interpret the data yourself.
As the DVD standard uses 3 different filesystems
ISO-9660, UDF 1.0.2 AND IFO
There is some jobs to be done, telling the ISO and UDF filesystem the our VTS_01_1.VOB is zero bytes long.
The third one, IFO is much more difficult (not impossible) to change. Many comercial copy protection does it.
And the IFO files tells the player where all files is on the disc, so it can not be tempted with unless you now what you are doing.
In order to create a copy protection for DVD, you need to know the differences between a stand-alone player and a computer.Originally Posted by Dv8ted2
A dvd-video disc has a very restricted rules for the filenames as described in the dvd-spec.
Also the location of these files are critical, because the player access the disc directly at certain location
to read data, and if the order should be wrong, wrong data is obtained
The computer on the other hand handles with hugh amount of data from the user, with various names and also different length. It is here the filesystem become important, because the computer has no way to asume where my powerpoint presentation is located.
If one don't understand this difference, the idea of copyprotection fails and become impossible
You completely missed my point. My teasing comment was directed towards saying that a disc controller could do it's job without a file system. They work in conjunction. You could have one without the other, but the filing system organizes the files for you.Originally Posted by ilovevcd
You also missed the part that data recovery software could bypass whatever protection you use. To protect yourself, you would have to do away with all software and computers. That seems like a very tall hill to climb.
This topic is starting to bore me so I will finally bow out.
Does it play in a range of stand-alone DVD players ?
Read my blog here.
Originally Posted by ilovevcdBecause you aren't making a DVD Video compliant disc anymore.Originally Posted by Midzuki
Look at a Disney DVD Video. It does not have the standard DVD Video logo on it. Instead is says something like, "Disney DVD" on it. Why? They can't use the logo as it is out-of-spec. So they made up their own "Disney DVD" logo. Losers.
So what you have is a deliberately corrupted data disc, not a DVD Video disc. Nice intellectual exercise, but not a realistic or practical copy protection system.Originally Posted by ilovevcdRead my blog here.
Protecting a dvd from being copied
By arnold.iceman in forum Authoring (DVD)Replies: 4Last Post: 14th Aug 2010, 10:12 -
Copying an already copied dvd
By Angel87341 in forum MacReplies: 8Last Post: 12th Feb 2010, 15:54 -
Copying a copied dvd
By Angel87341 in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2010, 13:56 -
Can a music CD be copied into a DVD?
By coody in forum AudioReplies: 6Last Post: 13th Oct 2008, 18:32 -
Prevent automatic scaling/zoom of picture when playing a DVD
By pk20 in forum Authoring (DVD)Replies: 5Last Post: 7th Sep 2007, 04:30
