  1. I have been trying to make a DVD, with no success, and I constantly have been getting an dvd author quit error.
    Never have I had this problem with ffmegX, as it has always worked but I remembered that I am now on Leopard.
    Anyhow I have copied the report that Leopard wanted to send to Apple and here it is , if anyone can make sense of this , I would appreciate it.
    Path: /Applications/ffmpegX.app//Contents/Resources/dvdauthor
    Identifier: dvdauthor
    Version: ??? (???)
    Code Type: X86 (Native)
    Parent Process: bash [8939]
    Date/Time: 2007-12-03 18:47:33.232 +0900
    OS Version: Mac OS X 10.5.1 (9B18)
    Report Version: 6
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000010
    Crashed Thread: 0
    Thread 0 Crashed:
    0 dvdauthor 0x0000f516 MarkChapters + 523
    1 dvdauthor 0x00004c1b dvdauthor_vts_gen + 361
    2 dvdauthor 0x00014901 main + 3783
    3 dvdauthor 0x00001cfa _start + 228
    4 dvdauthor 0x00001c15 start + 41
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x00000000 ebx: 0x0000f319 ecx: 0x00800000 edx: 0xa0023650
    edi: 0x00800c00 esi: 0x00000000 ebp: 0xbffff868 esp: 0xbffff7e0
    ss: 0x0000001f efl: 0x00010286 eip: 0x0000f516 cs: 0x00000017
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    cr2: 0x00000010
    Binary Images:
    0x1000 - 0xf4fdf +dvdauthor ??? (???) /Applications/ffmpegX.app/Contents/Resources/dvdauthor
    0x8fe00000 - 0x8fe2d883 dyld 95.3 (???) <81592e798780564b5d46b988f7ee1a6a> /usr/lib/dyld
    0x9011a000 - 0x90274fe3 libSystem.B.dylib ??? (???) <8ecc83dc0399be3946f7a46e88cf4bbb> /usr/lib/libSystem.B.dylib
    0x915a5000 - 0x915acfe9 libgcc_s.1.dylib ??? (???) <f53c808e87d1184c0f9df63aef53ce0b> /usr/lib/libgcc_s.1.dylib
    0x92e41000 - 0x92f35ff4 libiconv.2.dylib ??? (???) <c508c60fafca17824c0017b2e4369802> /usr/lib/libiconv.2.dylib
    0x935ed000 - 0x935eefef libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
    0x94381000 - 0x9438fffd libz.1.dylib ??? (???) <5ddd8539ae2ebfd8e7cc1c57525385c7> /usr/lib/libz.1.dylib
    0xffff0000 - 0xffff1780 libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
    I am using a 2.33 GHz Intel Core 2 Duo -Mac, with 3 GB 667 MHz DDR2 SDRAM
  2. I must add that this has also happened with MovieGate too. Also, ffmegX tells me it has finished and it does create a Video TS folder, however the folder is always empty, same as MovieGate does. I imagine it is something to do with Leopard as it never happened with Tiger, but I am not an expert.
