    Jan 2007
    When I use this program it converts to DVD fine, but the DVD won't play on my computer.
    Is this typical?
  2. It would help if you provided a little more information...
    What won't play on the computer?
    Do you mean the burnt DVD or the VIDEO_TS folder?
    Did you use convertx to burn or some other application?
    What software DVD player are you using?
    Jan 2007
    Sorry..
    I will burn to DVD using ConvertXtoDVD on a DVD-/+ R and it will read on DVD players, but not on my Computer.
    What can I do to fix this?
  4. So you are saying the DVD works fine with standalone DVD players, but not on your PC?
    What software DVD player are you using? Can you right-click and explore on the DVD drive with the DVD inside? Do other DVD's work? Has this happened before?
    Jan 2007
    No it hasn't happened before. I usually use Media Player, if I right click it comes up with the Audio and Video TS Folders, but if I play a Video TS it has sound only.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Media Player = ?
    Media Player Classic plays DVDs out of the box
    Windows Media Player cannot play DVDs unless a software DVD player has been installed, or you have sourced appropriate codecs. If you have tried to install codecs by using a codec pack then you may get unexpected results.
    Read my blog here.
