I'm planning to buy a DVD recorder and I want it to record copy-once programs. I've read the manuals of some recorders and they state that in order to record copy-once programs, you need to use DVD-RW media that is CPRM compatible ver 1.1 or 1.2. The problem is that no media that I've seen so far in stores specify this. I have asked employees and they have no clue. Are all newly available DVD-RW media CPRM compatible? if not, how do I know and where can I find them?
Email the mfrs. I think this was an initiative.. possibly now defunct.. I dont think such things exist(copy once programs) altho I stand to be corrected.
Cont... (sorry clicked submit before finishing)
... then I checked the manual (Philips 3475) and discovered that this unit will not record copy-once programs. I returned the unit and later found some units that will record copy-once programs but the media have to be CPRM compatible. I will buy one of this units but I want to make sure that this CPRM media is available.
Copy-once means that you are able to record the content but not able to make further copies. -
You will have to try a recorder that also uses DVD-RAM disk. DVD-Ram disk for video recording (cartridge less) have dropped sharply in price; check out the Panasonic 5-Pack at BestBuy.
I can't determine online if they comply with CPRM. I know you will not find any plus or minus, write once or re-writable DVD media in the U.S. that does. It will be DVD-RAM or nothing. -
Well, bite my tongue.
I know that the recording of "Record Once" programs is supposed to be possible using a CPRM recorder (in VR mode) on DVD-RW disk. But I don't know anyone who has been able to do it. My brother has used Verbatim, Sony, Imation (made by Phillips) and Memorex DVD-RW and failed to do so with three different brands of CPRM capable DVD recorders. They were all returned. The last one was a Sony.
But here you will find JVC DVD-RW, Ver. 1.1, CPRM. Maybe it is possible!
http://www.amazon.com/Jvc-Vdw47Eu5-Dvd-Rw-5-Pk-4X/dp/B0002EGFK8#moreAboutThisProduct
BD-R (Ver. 1.1 1L), BD-RE (Ver. 2.1 1L) discs
By mobie29 in forum Authoring (Blu-ray)Replies: 2Last Post: 13th Jun 2010, 14:57 -
CPRM compatible DVD -RW
By tbl35 in forum Newbie / General discussionsReplies: 8Last Post: 6th Oct 2009, 12:13 -
Any Blu-ray player that plays CPRM (VR mode) DVD-Rs?
By Mogree in forum DVD & Blu-ray PlayersReplies: 8Last Post: 3rd Jan 2009, 16:29 -
Removing CPRM on my Pioneer dvd-recorder 633, is this possible?
By mallanikkelsen in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Jun 2008, 00:27 -
Media player classic and MCE remote-compatible?
By bigshotceo in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Jan 2008, 12:18
