    Jun 2005
    USA
    HI all,
    I was wondering how should I make a photo collage of digital photos that I have. Is there any good photoediting free software that you can recommend??
    I want to get it done within this week.
    Many thanks!
    Photoshop is the best. Not free. Elements version is always in the $50-100 range.
    A trial is available! Work fast, and get it done before the 30 days are up.
    Jan 2006
    Photofiltre
    bits
  4. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Gimp is probably by far the most advanced free photo editor, a collage would be easy to make with it. I don't use it myself but if I was going the free route that is the first place I would look. Here's a quick tip. Make sure to add shadow to each individual picture, this will add depth and make it look a whole lot better.
  5. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    'Photo Collage':
    http://www.ifoxsoft.com/
    Jun 2005
    USA
    Many thanks for the replies. I'm adding shadow and depth and it looks good. Thanks for the tip.
    Btw, I'm using Collage maker 2.06 trial version for now.....
  7. Banned
    Jun 2007
    UNREACHABLE
    Stupid wannabe nerds like myself prefer to use
    VirtualDub + Avisynth + a pocket calculator.
    Alex_ander wrote:
    'Photo Collage':
    Pretty Asian women always are worth seeing ^___^
