Hello,
I'm using this tutorial to convert DVD to AVI: http://www.geocities.com/goodsharer/?200711
(As a note, the DVD was recorded from a VCR with a LiteON DVDR.)
The problem is, the original and resulting movies have noticeable motion combing (on each frame, not every other one) and I'd like to get rid of it, but I'm a noob and haven't found a good newbie tutorial. I've uploaded a small clip of the file so you can check it out.
Any suggestions?
Thanks,
David
clp.avi
That's not combing, it's interlacing, plus a healthy dose of blocking at the moving frames. If you use VirtualDub, the Deinterlace Muksun plugin is a pretty good deinterlacer: http://www.thedeemon.com/cgi/getfilter?id=119
deint.avi -
If I use that plugin, does that mean I need to put it into the process of conversion from VOB to AVI or can I just use it after it's been made into an AVI?
Thanks again,
David -
Much better if you use it during the VOB to AVI conversion. Lots of apps will do it automatically for you, although VirtualDub works just as well as the rest of them. AVIdemux also contains an excellent deinterlacer - Yadif .
No probs. You'll have to use VirtualDubMOD to open VOB files, BTW.
The latest version of VirtaulDub can open VOB and MPG files with the appropriate plugin:
http://forums.virtualdub.org/index.php?act=ST&f=7&t=14639 -
VirtualDubMPEG2 is also available and more up to date than VirtualDubMod.Originally Posted by Soopafresh
Cleaning up residual combing from hard telecined source
By txporter in forum Video ConversionReplies: 16Last Post: 30th Jul 2010, 16:15 -
combing avi's
By halekon in forum EditingReplies: 4Last Post: 2nd Aug 2009, 08:22 -
Combing in AVI files when transfered from camera to PC
By ChuckvB in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 25th May 2009, 07:03 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 19:50 -
dvdauthor authoring problem (combing 16:9 and 4:3 material)
By ecc in forum Authoring (DVD)Replies: 4Last Post: 5th Jul 2007, 20:14
