hi guys i have a zenith xbr716 dvd recorder/vcr combo
anyway it works when i put input on the tv but i cannot record off tv that way.
I am using a dvr box from comcast
how do i do this? i wanted to record tin man tonight.
If your recorder can tune the channels from your cable provider, then you just choose the channel and record.
If your recorder can't tune the cable channels, then you will need to connect the video output of your cable box to the input of your recorder. Then you set the cable box to the desired channel, choose line-in on the recorder, and record.
Of course, since you have a DVR already, you could record it on the DVR and transfer it later. The transfer process will be the same as outlined above.Google is your Friend -
Which means what? How is it connected? What exactly are you trying to record? Some shows/channels (HBO, Showtime, Pay-Per-View) can't be recorded from some providers.
Recording from DVR Cable Box to DVD Recorder crops the sides
By Bumbie in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Jan 2012, 13:40 -
Help With Blu-Ray and Cable Box Setup
By Anonymous531 in forum DVB / IPTVReplies: 6Last Post: 1st Oct 2009, 21:12 -
Question about DVD/VCR recorder and setup
By Crumb in forum DVD & Blu-ray RecordersReplies: 10Last Post: 25th Sep 2009, 16:50 -
Connecting Bellexpressvu box to current cable setup
By samouellette in forum DVB / IPTVReplies: 1Last Post: 29th Nov 2007, 09:41 -
Connecting/setup VCR/DVD recorder complicated
By peeaytee in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 14:00
