Hello all!
I just recently switched from cable tv to iptv. And yeah I just can't get the tv onto my tv tuner. I know I can't mix analog and digital tv but what can I do, what do I need to buy in order for me to be able to watch TV on my computer?
Most of all I annoyed that I can't record TV so If some external unit exist please post some links (it does not matter if I cannot watch tv on my computer as long as I can record it).
My current hardware:
IPTV "box": Motorola VIP 1910 HD enabled
TV tuner #1: Pinnacle PCTV Rave
TV Tuner #2: WinFast 2000xp Expert
Please advise,
shorto
You can't record composite or S-Video off the SCART connector?Originally Posted by shorto
http://broadband.motorola.com/newProductInformation.asp
http://www.motorola.com/mot/doc/6/6346_MotDoc.pdf -
I think normal Scart outputs RGB and adapters are needed for S-Video. Others are in a better position to comment, or your IPTV provider should know what you need.Originally Posted by shortoRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If it's just a b&w problem it might be due to a PAL/NTSC issue. If your Motorola is PAL and your tuners are NTSC you might need a converter. Also, how you connect is not clear at all.
IPTV streaming
By shorto in forum Video Streaming DownloadingReplies: 0Last Post: 2nd Aug 2011, 15:04 -
iptv receiver
By adrian.kratky in forum Media Center PC / MediaCentersReplies: 5Last Post: 28th Oct 2010, 14:08 -
TV over Internet - IPTV question
By siluet in forum DVB / IPTVReplies: 9Last Post: 5th Feb 2010, 16:56 -
JVC DR-M100 looks wahed out on tuner & line in
By carnivore99 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 19th Feb 2008, 20:29 -
IPTV recording format
By shorto in forum DVB / IPTVReplies: 3Last Post: 12th Dec 2007, 06:40
