Am I handling Audio Delay Correctly? Any potential A/V Sync Issues?
Here's what I'm doing.
1. I'm converting VHS tapes to DVD via VCR to Hauppauge USB2 external capture card.
2. Video is 720 x 480. VBR w/max = 6000 kbps & average determined by run time of the video to fit on a SL DVDR.
3. Audio is MPEG1 layer 2 at 384 kbps. I plan to convert this audio to ac3 at 192 kbps, which gives me a little more bit rate for the video. However, the biggest reason I want to convert is in order to clean it up using Goldware.
4. After capture, I use DGIndex to generate a d2v file and to extract the audio.
5. I then use VirtualDub to open the d2v file w/audio via an avs script and then save the audio as an wav file for cleanup with Goldwave.
6. Here is an example of the avs script that I use,
7. Does my method, as illustrated by the above script, properly account for audio delay?Originally Posted by AVS Script
8. After clean up, including volume adjustment, using Goldwave, I use ffmpeggui to encode the audio to ac3 at 192 kbps.
9. I author using TDA 1.6.
10. In addition whether or not I'm correctly handing the audio delay, are there any other things in my method that might cause audio/video sync issues?
	I use Delaycut, which autofixes errors in the .mpa file and fixes the delay automatically as well.
 FixMPA.bat
 Then, add the .mp2 file to the avisynth script WITHOUT delayaudioCode:for %%a in ("*.mpa") do delaycut -fixcrc silence -auto -out "%%~na.mp2" "%%a"
 Or, you can automate it further, decoding to WAV and normalizing the audio via command line
 Code:for %%a in ("*.mpa") do delaycut -fixcrc silence -auto -out "%%~na.mp2" "%%a" for %%a in ("*.mp2") do ffmpeg -i "%%a" -vn -ac 2 -y "aud-%%~na.wav" for %%b in ("*.wav") do normalize -l 0 --peak -v "%%b"
 normalize.rar
  Audio out of sync, how to determine delay needed.By mattstan in forum Authoring (DVD)Replies: 9Last Post: 23rd Dec 2019, 03:26
  audio sync problem, how to work out progressive audio sync delayBy jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09
  Video scattering , audio sync variable delay in MKV filesBy prabhakarlad in forum Software PlayingReplies: 13Last Post: 22nd Apr 2011, 15:55
  Audio with delay making the proper syncBy ranosb in forum AudioReplies: 1Last Post: 25th Jul 2009, 22:09
  TBC delay / sync issues..By thegreatbear in forum RestorationReplies: 0Last Post: 22nd Apr 2008, 06:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
