how would the average DVD-player react if we feed it with a DVD±R including (S)vcd tracks, burnt in normal (s)vcd mode? becouse of the extra sector story it should mean you have a ± 5.3gb (s)vcd.
perhaps something interresting to test out. its a nice for some people to have 5:20 hours of storage room
NdZ
(PS the ± is alt 241)
Is it even possible to burn in mode2 form2(VCD,SVCD) on a dvd-+r/w??...I dont think so but I'm no dvd-+rw expert.
i have no idea Baldrick, i heared from some (unrelyable) sources it was possible. its only bad luck i am unable to test it out.
It works! I just tried it. It will perhaps not work on EVERY dvd player, as I only tried one. but it DOES work, and in case you have rest my last post, you know I tried it :)
lorez: so you burned in mode2 form2 on a dvd+rw? what authoring/burning tool did you use???
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 02:25 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
