So far have tried Rad video tools (which produced split screen distortion) and Boilsoft movie converter (whose image was OK but sound/vision synch was hopelessly out. Any gurus out there got a suggestion for other software that might work?
Rad Tools depend on which codecs you have installed. MOV to AVI works fine when I use XviD, which you can google for if you do not have it yet. It's one of those open source types. The best thing about it is that you can merge MOV files into one big AVI (instructions on how to do this are here) If you want to change frame rate, VirtualDub, I think, does the best job, but you can not open MOV files with it.
I love it when a plan comes together!
Converting Quicktime to Windows Media Player???
By TheShape in forum Video ConversionReplies: 3Last Post: 21st Feb 2010, 17:07 -
Trouble converting .mov to mpg
By jay_lubb in forum Video ConversionReplies: 1Last Post: 9th Mar 2009, 02:14 -
Problem converting quicktime .mov files to mpeg-1
By jtk in forum ffmpegX general discussionReplies: 8Last Post: 2nd Sep 2008, 18:42 -
Suggestion for converting hundreds of mov quicktime files
By m021478 in forum Video ConversionReplies: 0Last Post: 15th Aug 2007, 15:16 -
Quicktime to Windows MOV-mpeg-4 conversion problems?
By Simone in forum ffmpegX general discussionReplies: 4Last Post: 16th Jun 2007, 06:50
