    Nov 2007
    All my final cut studio applications work on my G-5 with Leopard except for COLOR. When I try to open it, it says that it doesn't have enough VRAM. I have no idea what that means. Does anyone know?
    Thanks.
  3. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    G5s have come with a variety of videocards, from the nVidia GeForce FX5200 w/ 64 MB VRAM (low end first model), and Radeon cards to nVidia Quadro FX 4500 with 512 MB (high end last model).
    See 'System Profiler' > Hardware > Graphics/Displays to see what's inside your Mac.
    You may be able to buy a videocard with more VRAM. Make sure it fits/is compatible with your type of G5's bus type (AGP or AGP Pro, PCI or PCI Express).
