Hey Folks,
Just got a new home computer. Major upgrade. I was doing conversions on a 600mhz and now I have 2 gigs. Heaven. But, it's a Vista machine. So far so good. But I'm having some issues with the camcorder capture on my firewire. I used to use WinDV, but it doesn't seem to work with Vista. The system has Roxio installed and it fires up when I turn on the camcorder, but it locks or restarts the system almost every time. And Windows Movie Maker doesn't even see the Sony Camcorder.
Can anyone suggest a reliable piece of software to capture direct from my camcorder to AVI?
Thanks!
Hal
Results 1 to 12 of 12
I'm afraid. I'm afraid, Dave. Dave, my mind is going. I can feel it..... Yup. Spppllttt. It's gone.
Try this. I was having the same problems with WinDV under Vista until somebody pointed out the DirectX End-User Runtime Update. For some reason, this doesn't show up under Windows Vista Update but seems to be necessary.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b665...displayLang=en
Let me know if this works for you because my machine has other updates that may have caused WinDV to start functioning.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If WMM can't see the camcorder, WinDV won't either. Both use the same underlying OS functions to do the capture etc.
Uninstall Roxio and just use Vista's built-in capability.
Roxio, Pinnacle and Nero are notorious for screwing up camcorder detection.
When you turn on the camcorder, choose the appropriate option on the menu that pops up. -
Looks like I have a similar problem.
I just got my new Vista PC up and running... my WinDV can't see my Canopus ADVC-100. Windows Movie Maker sees it just fine.
Any idea why this is?
Thanks! -
That's what mine was doing before I ran the DirectX End-User Runtime Update.Originally Posted by Robert SimandlRecommends: Kiva.org - Loans that change lives.
Just gave that DirectX runtime update a shot. Unfortunately it didn't help. WMM and DVapp see the ADVC-100 just fine (as they did before) but WinDV still says "device not found."
Any other suggestions? WMM, DVapp, and Scenalyzer all do a lot more than I need a DV program to do. I'd like to keep using WinDV if possible.
Thanks! -
WinDV works on Vista here. It didn't initially. Try to uninstall then reinstall.
What cam??
How do you capture??
Is it USB or firewire???
If it's USB , there-in lies your problem.... -
I bought a Vista Prem notebook w/Firewire today. I'll try WinDV on it tomorrow and report back.
My ADVC-100 is working fine now on the Core2Duo desktop.Recommends: Kiva.org - Loans that change lives.
looking for digital camcorder software
By TracyH in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Aug 2011, 00:10 -
windows vista and software for camcorder
By ray316 in forum ComputerReplies: 5Last Post: 28th Jun 2009, 20:02 -
digital 8 camcorder purchase
By Surfmaster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 22nd May 2009, 21:57 -
Video 8 to digital. Premier on Vista
By arlingtonmax in forum Capturing and VCRReplies: 1Last Post: 8th Dec 2008, 13:51 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 13:47
