Hi, recently I started to burn anime onto DVD's to watch on tv but came across a few problems.
The anime had subtitles on them and when I burn the original files the disc works fine but then the image is too large for the TV so the subtitles appears of the screen.
So I tried resizing it then burning, this worked so that the subtitles appears on screen completely without a problem, but then the image is all squished and looks ugly compared to the orignal, so I was wondering if there is a way around this.
I generally use virtualdub then use the resize filter and then burn, but then the lines are all jagged and the anime characters looks all squished, so its ugly.
Do a search on overscan to understand more about what you're up against.
I would suggest that you use FitCD (see FulciLives' guide here) https://forum.videohelp.com/topic296341.html#1487285
Good luck!In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move.
Having trouble with Subtitle Workshop
By jbitakis in forum SubtitleReplies: 10Last Post: 29th Jan 2012, 22:05 -
DESPERATE subtitle help -- trouble merging or making another channel
By andrewzors in forum SubtitleReplies: 14Last Post: 17th Jun 2011, 16:09 -
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
Trouble with smi subtitle files
By himrich in forum SubtitleReplies: 2Last Post: 31st May 2010, 17:32 -
Trouble adding permanent subtitle to xvid, subs don't break right
By boblydan in forum SubtitleReplies: 8Last Post: 18th Jul 2008, 19:53
