Hallo to the forum, I'm new here...
I need some help with cinellera, i can't understand why he doesn't import an avi file...
the error is
virtual int fileMOV::read_frame(VFrame*):quicktime_read_frame/quicktime_decode_video failed result:
these are details of the files I'm trying to load
AVI file format detected.
VIDEO: [DX50] 480x272 24bpp 23.976 fps 625.3 kbps (76.3 kbyte/s)
xscreensaver_disable: Could not find XScreenSaver window.
GNOME screensaver disabled
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4)
Forced audio codec: mad
Opening audio decoder: [libmad] libmad mpeg audio decoder
AUDIO: 48000 Hz, 1 ch, s16le, 64.0 kbit/8.33% (ratio: 8000->96000)
Selected audio codec: [mad] afm: libmad (libMAD MPEG layer 1-2-3)
AO: [alsa] 48000Hz 1ch s16le (2 bytes per sample)
Starting playback...
VDec: vo config request - 480 x 272 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.76:1 - prescaling to correct movie aspect.
VO: [xv] 480x272 => 480x272 Planar YV12
the error is about quicktime, but this is not a mov file...
can anyone help? it works with other similar avi files..but not with this..
thank you
renty
Results 1 to 1 of 1
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 517Last Post: 23rd Oct 2017, 11:09 -
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 06:33 -
Question about "DMA is not Enabled" warning message on DVDFab Pla
By jimdagys in forum DVD RippingReplies: 14Last Post: 20th Jan 2009, 15:54 -
RETAIL DVD plays in standalone - "No Disc Inserted" message in PC
By prattitude in forum Software PlayingReplies: 6Last Post: 28th Nov 2007, 13:07
