    Nov 2007
    OK, I was told that I should change the speed for slow motion when editing. However it seems choppy and not so fluid. I am editing HDV 60i and I dropped the speed 50%. Is there any other way to create slow motion?
    Nov 2007
    it seems the 60i is the problem. I read somewhere about using motion. Any tips?
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    James, you have the whole FCS2package correct?
    if so you should spend sometime reading the manuals
    for motion and the chapters on retiming technique.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Nov 2007
    I know I should, but I live in a information now world, so instead of searching forever in a thick as book with smaller writing then the bible, I just thought I would give this a shot. I figured it can't hurt.
  5. Member terryj's Avatar
    unfortunately my friend, since your swimming in unfamiliar waters
    for some of us ( using HDV instead of SD), the manuals are going
    to be your friend in the information you seek.
    You might also try a local MUG in your area; they are more plentiful
    and chances are you will find people doing what you do, and can share
    ideas with them.
    Urban Mac User
