Te traies.
I have bought a hidden camera called Spy Cam Stick. Iam working to a project now that requires hidden cameras. I have ordered my cameras from USA and they just arrived.
I am under the impression that this cameras works fine on Apple platform but you need drivers and 3gp codex's for a windows platform. As usual, the producer is a no name there and do not have give them. I do not have Apple. The problem is that when i plug in through the USB cable it does not say "find new hardware"! Does not say anything!
Do you have any idea what i should do?
it does not come with any software since they say it should work through the USB cable and you need to instal quicktime player or Real time player. I have instaled Quick time.
They say it is produce for bouth Apple or PC. My friend from US tried it on Apple through the Sd card device(not USB cable) and it worked. I can not do that since i do not have an Sd adaptor. Will do that on Monday, but the point is that they say it should work as an USB and do not understand why it doesn't say "find new hardware!".
The camera is digital 3GP: the NTSC/PAl is not an issue here.
My PC is powerful enough to read the hardware
I have installed the SD card in the camera and i have tried on my laptop too. Does not recognise new hardware.
I think i need driver and 3gp. I am not sure. Any sugestions?
If this work only to Apple then i am in trouble. Maybe if i can find a driver that will allow me to transfer this to a windows platform, a way to trick the computer.
				Results 1 to 1 of 1
	Jorj
  Common pro video cameras c. 2002 (capturing-related!)By moxiecat in forum Capturing and VCRReplies: 10Last Post: 13th Jan 2012, 21:04
  Capturing hardware adviceBy johnestan in forum Capturing and VCRReplies: 0Last Post: 24th Sep 2011, 20:13
  Newbie needs some advice - capture card so I can record several cameras?By wiemos in forum Capturing and VCRReplies: 4Last Post: 19th May 2011, 03:41
  Capturing from 2 different camerasBy wolfab1968 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2010, 11:54
  Converting Streaming Video Format(s) to 3GP --> Any Advice & SuggestBy SnakeGirl in forum ffmpegX general discussionReplies: 0Last Post: 21st Jan 2008, 09:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
