I've been encoding for a while using tmpeg encoder & a couple different templetes. My question is, is there a significant quality difference between encoding a vcd using the highest quality setting, and the high quality? I know it takes hours longer, but besides that, I don't see and major difference. I guess my real question is what do most of you that use tmpegenc set the quality setting at?
Also, at whats the quality of the motion search setting?
I'm interested in finding out because I see a lot of films being swapped, downloaded, distributed, and I'd like to make sure that the quality I encode at is par. Thanks much.
"The Ivy League doesn't teach you how to chew, you gotta learn that yourself!"
Results 1 to 1 of 1
best xvid settings for high quality
By dirtyharry61 in forum Video ConversionReplies: 20Last Post: 21st Mar 2016, 08:49 -
best motion search option to increase encoding speed while keeping quality?
By visualhippocracy in forum Video ConversionReplies: 4Last Post: 13th Jan 2011, 10:40 -
HELP! RipBot Settings for Highest quality HD-DVD to Blu-Ray Project
By clarkkent57 in forum Blu-ray RippingReplies: 6Last Post: 9th Sep 2010, 12:58 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 06:23 -
Tmpeg enc Plus 2.5 selects wrong Aspect ratio
By wozmac in forum Video ConversionReplies: 6Last Post: 15th Jul 2007, 17:31
