May i know how to reduce video bit rate ? except reduce video bit depth, video resolution and video frame rate. Will have any big drawback to the video ?
You reconvert/transcode the video and yes you will lose some video quality depending how much you reduce the bitrate. If it's a dvd use dvd shrink, dvd rebuilder, etc.
By reencoding at a lower bitrate. Lower bitrate = lower quality. And every time you reencode you lose some quality (regardless of bitrate used), so reencoding to a lower bitrate is losing quality 2 ways.
In fact neither reducing video bit depth nor video resolution nor video frame rate reduces bitrate, but they all allow for the use of lower bitrate.
/Mats
Can you reduce video (MKV/H.264) Bitrate withOUT re-encoding?
By KushSmoka420 in forum Video ConversionReplies: 4Last Post: 14th Mar 2012, 04:17 -
How to reduce video bitrate of a MKV file?
By doronb2 in forum Newbie / General discussionsReplies: 14Last Post: 3rd May 2010, 21:25 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 18:29 -
How to reduce resolution and video bitrate in XviD AVI files?
By hibbs in forum Video ConversionReplies: 2Last Post: 13th Jan 2009, 11:50 -
reduce bitrate of mpeg file
By bradlewa2 in forum Newbie / General discussionsReplies: 10Last Post: 24th Apr 2008, 09:32
