Using ConvertXtoDVD I forgot to untick 'auto-start playback' . I had created a menu with 2 items. Although I can access the menu if I select Title Menu after starting the authored files on my hard disk, I remember once before, several years ago, I used IFOEdit to correct the auto-start feature back to loading in the menu first...... I've forgotten what to do- any help greatly appreciated. It's probably in VMGM_MAT somewhere!!!
or ifoedit if you wish. open the video_ts ifo and double click the VMGM_MAT to expose the first play pgm. select it and scroll down in the lower window to the pre commands. find the one that says something like jump to title. right click on it and change it to (JumpSS_VTSM) Jump to Titleset Menu and select 1 and 1 for the numbers. click ok and then save at the bottom.
yeah! many thanks that did the trickOriginally Posted by aedipuss
I used IFOEdit as I'm not all that familiar with PGC
2 small questions about authoring with IFOEDIT
By i_j_2009 in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2010, 11:15 -
Which dvd authoring software should I use? IFOEdit keeps crashing.
By architectofpain in forum Authoring (DVD)Replies: 4Last Post: 4th Aug 2009, 06:54 -
Avi index error in vdubmpeg2 - how to correct?
By yoda313 in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 21:44 -
Encoding/AUTHORING short film to DVD (w/ CCE and IFOedit)
By sunsetblvd in forum Authoring (DVD)Replies: 13Last Post: 8th Aug 2007, 16:37 -
Correct Terminology for authoring?
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2007, 03:45
