I am trying to burn entire dvd disc. How is Nero set up? Currently, it says I do not have enough room on my C drive, which has about 3.7 gigs left. The dvd-r needs about 4.4 gigs. I went to FILE--> PREFERENCES---> CACHE and the destination is set to my C drive.
Also "Minimum disk space reserved" is 16 MB....what does this mean?
I never knew that when you burn dvd to dvd, you still need "space" on your hard drive?
With the assumption that the DVD that you want to burn from does not have copyright protection (i.e., no illegal stuff), here's my answer:
Nero can copy disc to disc, without using the hard drive.
Open Nero Start Smart, select the DVD (not CD) icon at the top right corner. Hi-lite the Copy and Back Up icon (the icon with the 2-disc image), then choose Copy Disc.
Next, choose "Quick Copy" (check mark), your source disc, your destination, the proper writing speed for your disc and the number of copies you want to make.
Click "burn". Sit back and enjoy a cup of tea/coffee while Nero does its job.
Ahh, thank you, what is the difference between using my hardrive versus copying disc to disc?
Originally Posted by jyeh74
*SATA drives are not affected.
Trying to burn a dvd using dvd shrink and Nero 10, please help a newbie?
By KtuluAlly in forum DVD RippingReplies: 6Last Post: 30th Dec 2010, 13:33 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
How to burn DVD data with Nero 7?
By Kakui in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2007, 16:00 -
why could I only put two movies on a DVD disk when I use Nero to burn DVD?
By efang622 in forum Authoring (DVD)Replies: 7Last Post: 24th Oct 2007, 08:40 -
Nero DVD-R image will not burn to DVD+R
By johnnyelectron in forum Newbie / General discussionsReplies: 3Last Post: 15th May 2007, 20:50
