For years I've used VideoRedo to edit my MPEG2 captures from my PC tuner cards. I only want to get rid of commercials. Now that I have an HDTV tuner, I have a problem. I just tried it with VideoRedo and it didn't work because it can't edit (cut) Dolby Digital audio.
Is there a program out there that is as reliable and easy as VideoRedo, but works with AC3 audio and can cut that too? The idea is to simply save the new file with my cuts out, without recompressing any video or audio if possible.
If there is a commercial product which makes this easy, please mention that too.
Thanks!
Robert
MpegStreamclip or AviDemux should do it fine.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
AVIDemux seemed to work until I saved the file, then it flashed the process for 1 second and exited. I ended up with a 6MB file of the first 5 seconds or so. Since it was an HDTV capture, I would not be surprised if there were some errors in it that I can't detect upon viewing. (that's my layman's guess). Is it possible that AVIDemux is croaking on those? Any other way to make sure it can continue with the process?
Robert -
You've got a file with some corruption in it. Fortunately, there are many tools that can address this. Mpeg2Repair works quite well at fixing the file (usually).
https://www.videohelp.com/tools/MPEG2Repair
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Software Order and use. Edit Sony Camcorder mpeg2 video.
By gerritv in forum Newbie / General discussionsReplies: 1Last Post: 22nd Oct 2009, 02:12 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 21:52 -
Edit MPEG2 video without encoding
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 22nd Feb 2009, 13:05 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24
