Results 1 to 22 of 22
    Mar 2004
    Wheeling, WV
    I am trying to convert a .mkv video file and I don't know how to do it. My TMPGEnc DVD authoring program doesn't like that file type it seems and id like to get it to either .avi or .mpeg. Can anybody give me any suggestions?
    alltoavi if you want to convert to avi divx/xvid. convertxtodvd if you want a dvd.
  3. Member RainGoddess's Avatar
    Dec 2007
    Philippines
    i'm using convertxtodvd, but when i convert mkv to dvd through this program, subtitles disappeared! help please...
    You first say that there are no subtitles using convertx and then that are subtitles but they are too low? You can move the subtitles higher in converxtodvd, under settings->subtitles and Text subtitles rendering settings change the Margin vertical value.
  5. Member RainGoddess's Avatar
    Dec 2007
    Philippines
    thanks baldrick!
    the case in which the subtitles are too low was on my avi files not on mkv.. (thanks for the guide!)
    about the subtitles who disappeared.. i finally solved it! here's how:
    1.) I extracted the subtitle file using MKVExtractGUI
    2.) Loaded in Subtitle Workshop and saved it in srt format (previous format = ass)
    3.) Converted the mkv to mpg/avi using TMPGenc
    4.) Merged the new file with the new corresponding subtitle using AutoGK
    5.) Made it into a DVD using ConvertXtoDVD
    that's it!!
    after weeks of finding ways..finally, I made it.. thanks to this forum!!
    Athens, Hellas
    is TMPGEnc able to do this conversion (bold words)?
  7. Member RainGoddess's Avatar
    Dec 2007
    Philippines
    precisely..with the help of the codecs...
    Question, I already adjusted the settings so that the subtitles will be a bit higher.. but it doesn't work on permanent subs..do I have to subripped it, then the usual process?
    Dec 2007
    Errrmm. I can't figure out how to get it to recognize an Mkv file. Help!
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I don't know of any program that converts mkv files and correctly detects the subs inside the mkv container and uses them. Use MKVExtract the gets the subs out, convert them to SRT format, and ConvertXtoDVD or FAVC can turn them into switchable DVD subs correctly.
    Read my blog here.
    Dec 2007
    Now I have a problem with AutoGK. I have the Subtitles in .srt, and the unsubbed AVI's. when i select the avi in autoGK, no subtitle tracks show up. How can I get them to show up so they can be selected
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    What do you need AutoGK for ? If your target format is DVD, don't throw a generation of quality away converting to Divx first. Use ConvertXtoDVD or FAVC with the original MKV file and the srt subs and go straight to DVD.
    Read my blog here.
    Dec 2007
    I'm just trying to get it to Xvid, for I am putting it on my ipod. they subs are large enough to read, so don't fret. However I can't get the subs to display properly
  13. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Now you are changing the rules of the game.
    Use AlltoAVI to convert mkv files to Xvid
    Read my blog here.
  14. Member RainGoddess's Avatar
    Dec 2007
    Philippines
    Please answer this...
    Dec 2007
    New error with a different project:
    I have the Mkv and the subs in both .ass and in .srt, converting to DVD with my new copy of ConvertXtoDVD. When I watch the preview window, the subs do not show up. Why? It is also saying in a gold colored box in the log: error while decoding stream #0.0. Also, if I do get this to work, how do I make sure that the subs will come up, since I do not know how to make a menu regarding enabling subtitles from the DVD player.
  16. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    On the Subtitles tab under preferences/settings there is a tick box to turn on the default subtitle automatically. Of course, you can just use the subtitle button on your remote as well.
    Read my blog here.
  17. Member RainGoddess's Avatar
    Dec 2007
    Philippines
    Or you convert mkv to avi using TMPGenc then merge with the subtitles and the avi file using AutoGK..
    I have experienced that problem before..
  18. Member
    Dec 2007
    I can't manage to do this. How do you get the subs into the program?
  19. Member RainGoddess's Avatar
    Dec 2007
    Philippines
    after adding the avi press ctrl + f8 to bring up the subtitle load
    or check this out:
    https://www.videohelp.com/tools/AutoGK
    Dec 2007
    Finally got it! Thank you all!
    Nov 2008
    here
    Hi, All
    I am trying to convert *mkv files to *avi. I am using Alltoavi. After typing in all the needed info, and hitting the "convert" button, i am getting the following error message:
    "Run-time error '70':Permission denied"
    Anyone knows what is going on?
    Thanks for the help!
    ebolaz
  22. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Are you working in an administrator account on your PC ?
    Are you writing to a disc that has enough space ?
    Are you writing to a disc that you have permission to write to ?
    Read my blog here.
