i got hold of amv converter. guide is here http://www.mympxplayer.org/how-to-convert-to-amv-using-the-mp3-player-utilities-368-vt32.html
but everytime i try to convert an avi file, like a music video for example, it keeps coming up "FAILED TO REG"
seems to convert video, but no sound wen i put it on mp3 player
any ideas???
cheers in advance
or if possible suggest a different program, am running vista if that makes a difference
go on give a newbie a chance
Most likely the tool doesn't support the file type you are trying to import.
There are some tips here: http://www.s1mp3.org/wiki/index.php/Video_encodingGoogle is your Friend
Best Way To Convert DVD, AVI to AMV Format
By dougwx in forum DVD RippingReplies: 6Last Post: 21st Dec 2013, 03:47 -
I need help with my AMV converter!!?
By spring1 in forum Video ConversionReplies: 1Last Post: 23rd Feb 2010, 05:37 -
AVI to AMV
By snadge in forum Video ConversionReplies: 6Last Post: 18th Dec 2008, 10:49 -
Transferring MPEG-2 file from the Favc conersion to DVD using Nero 8 (Vis 5
By pay1000 in forum Video ConversionReplies: 5Last Post: 29th Jun 2008, 21:24 -
WMV to DVD conersion
By uniks in forum Newbie / General discussionsReplies: 6Last Post: 31st Aug 2007, 07:25
