:-? I seen feedback that doesn't recommend Easy Cd Creator, doesn't it work to burn VCD if so what is the best software to do the job????? limited knowledge so plain english please.
Hi, I'm very new at all this stuff to so you should understand me. I have easy cd platnum 5 and I could not create a VCD that would work using it. I placed a post just like yours asking for help and the advice I was given has been very helpful. Firstly I was told that easy cd does not make compliant VCD'S. Secondly I was told to use the "how to's" on this site to make a coplant VCD. To be honest with you when I first looked at them before placing my post it was like they were written in a different language but I took a look at the again and had a go at it and it worked.
First go to how to capture & follow the instructions on how to capture using virtual dub.
Then go to how to convert & follow the instuctions on how to convert using tpmgenc.
Then go to how to aurthur & follow the instructions on how to aurthur using VCDEASY.
All of the above are freeware & I was able to download them from this site.
I am now able to burn a VCD that will play on my standalone VCD player which I was not able to do using easy cd.
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 14:26 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 14:33 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 15:27
