After my run of bad luck with HCEncGUI and DGIndex, I encoded an avs script (with assumefps 23.976) in FreeEnc after adjusting the ini file to get a higher bitrate. The file had the right NTSC running time in GSpot at 23.976 and then after I used DGPulldown. When I plugged it into DVDAuthorGUI, I got the error "too many dropped frames -exiting". Just muxing it with Imago Muxer didn't bring up an error but it quit at approximately the same place.
The threads I got looking this up have mostly to do with dropping frames during capture and some have suggested using ReStream to correct the problem. Can ReStream of any other program do anything about whatever this new issue is?
Results 1 to 1 of 1
how to "force dropping frames on the fly"
By adom in forum Software PlayingReplies: 7Last Post: 10th Mar 2012, 13:13 -
how many b-frames is "optimal" for h264 encoding?
By deadrats in forum Video ConversionReplies: 8Last Post: 31st Dec 2011, 18:26 -
VLC Media Player - "Lost Frames"
By Ancalagon in forum Software PlayingReplies: 3Last Post: 18th Feb 2010, 05:57 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 18:49 -
Error message "CMOS checksum error - Default loaded"
By ChrisKS in forum ComputerReplies: 1Last Post: 27th Jun 2007, 01:16
