Hi all
After MUCH trial and error I finally found the correct settings to convert movies to work on the PS3 but I cannot seem to get 5.1 no matter what I do...
I am running an Intel Mac in case someone wants to nock my hardware :P
I am using MKV files as source with audio either AAC 5.1, AC3 5.1 or DTS. DTS I get no audio no matter WHAT I do and with the other two I always get AAC Stereo even if I just use passthrough for the audio. So what's up? What do I need to do to get 5.1 in my videos?
My setup (for my current video) is as follows:
Video- h264(x264) - 2500kb/s - 1280x544 - 16:9 - ntsc fILM
Audio - Passthrough (or AC3, depending on mood) - 448kb/s - Source - 5:1 - CBR - Audio Track 0
Options - CABAC - Constant - Trellis - QT - 4.0 - 22 - 51
I just realized something... I have the QT option selected but when I try to encode a movie for the PS3 via QT directly, it does not give me the passthrough option or a 5.1 option, only AAC stereo option... I wonder if i encode the video without this option if it would make any difference?????
I will try it now, but if you have any advice, please do help me out.
Thanks in advance
				Results 1 to 10 of 10
	Here is a trick to get passtrough video and audio :
 http://www.redkawa.com/forums/showthread.php?t=1906Originally Posted by Red Kawa
 Here is a tips if you plan to burn the file on a DVD-Rw : Rename output.vob to output.mpg...
 You can use iMkvExtract to demux the MKV and an OS X compiled ffmpeg version, but the H264info tweak is not yet available natively and have to be done via BootCamp or Virtual Machine (Fusion or Parallels)
 I tried several MKV and it works great on most... Only one had a frame rate issue and it was a TV Rip...
 The only limit is the PlayStation 3/DVD-Rw's file system.
 The internal HD doesn't support files larger than 4GB and burned DVD can't get larger than ±4.4GB...
 But you can cut the source file with MkvMerge.
 When he'll have time, maybe Major could look closer at the subjet and include some new features to a (possibly !) future version of ffmpegX.
 'hope this helped...
	Thanks, mate. Will try it out and see if it works... now the first step is finding ffmpeg. I absolutely cannot stand CVS (if spelled right, that is) and since a precompiledpackage does not exist, I guess I will simply have to see what I can do. Thanks for the tip
 I tried doing pasthrough and re-encoding as AAC 5.1 and like you said, it defaulted back to AAC Stereo.
	as I said... compiling from source... blahhhh...
 following the install instructions:
 I get the following errors:./configure
 make
 sudo make install
 and install either silently fails or gives me this cryptic(useless) usage instructions for install:make[1]: *** [i386/dsputil_mmx.o] Error 1
 make: *** [install-libs] Error 2
 Do I now first have to buy a book on Unix to learn how to work with the shell just in order to install ffmpeg? is there no easier way?usage: install [-bCcpSsv] [-B suffix] [-f flags] [-g group] [-m mode]
 [-o owner] file1 file2
 [-o owner] file1 ... fileN directory
 install -d [-v] [-g group] [-m mode] [-o owner] directory ...
 iMac:ffmpeg jacco$ install
 iMac:ffmpeg jacco$ install all
 Just tried make again and now it tells me:
 Ai jai jai jai jai... What's the point of having a GUI for an OS if one has to struggle with sh*t like this..???make[1]: *** [libavcodec.51.dylib] Error 1
 make: *** [lib] Error 2
	Holy cr*p... just randomly enabling and disabling any setting I couldfind and IT COMPILED. WHO KNEW!!!!???
 /me quits getting over-excited like Hiro from Heroes, flds his arms, frowns, sticks out his bottom lip and mumbles softly: "Stupid command line hassles. Ghmpff!"
 First edit...
 OH, btw, sorry guys, just noticed the EDIT button. I won't make multiple concurrent posts again. Please forgive this time :/ ???
 Second edit...
 Okay, so I managed to compile ffmpeg using --disable-vhook --disable-shared --enable-mmx
 Then I tried the command above after extracting the audio and video from the MKV file and saving as MOV files since QT only allows this option...
 So Here is the (very long) error message(s) I get. What is going on here?
 Assistance, please...
 I got it to work by taking out the "force to format" bits for audio and video. The filesize was consistent with simply copying in the two files but the file was not playable on my Mac or on the PS3...iMac -men jacco$ ffmpeg -r 23.976 -f h264 -i video.mov -f ac3 -i audio.mov -vcodec copy -acodec copy -f vob xmen.vob -men jacco$ ffmpeg -r 23.976 -f h264 -i video.mov -f ac3 -i audio.mov -vcodec copy -acodec copy -f vob xmen.vob
 FFmpeg version SVN-r11118, Copyright (c) 2000-2007 Fabrice Bellard, et al.
 configuration: --disable-vhook --disable-shared --enable-mmx
 libavutil version: 49.5.0
 libavcodec version: 51.48.0
 libavformat version: 52.1.0
 built on Dec 1 2007 01:34:26, gcc: 4.0.1 (Apple Inc. build 5465)
 [h264 @ 0x417330]non existing PPS referenced
 [h264 @ 0x417330]decode_slice_header error
 [h264 @ 0x417330]no frame!
 [h264 @ 0x417330]slice type too large (2) at 0 0
 [h264 @ 0x417330]pps_id (-1) out of range
 picture size invalid (16x0)
 [h264 @ 0x417330]mb_width/height overflow
 picture size invalid (0x3840)
 picture size invalid (0x240)
 [h264 @ 0x417330]illegal POC type 3
 [h264 @ 0x417330]illegal POC type -1
 [h264 @ 0x417330]too many reference frames
 picture size invalid (7296x0)
 picture size invalid (0x9216)
 [h264 @ 0x417330]illegal POC type 4
 [h264 @ 0x417330]illegal POC type 5540
 picture size invalid (0x0)
 picture size invalid (506496x0)
 [h264 @ 0x417330]slice type too large (3) at 0 0
 [h264 @ 0x417330]slice type too large (5) at 0 0
 [h264 @ 0x417330]poc_cycle_length overflow 4294967295
 [h264 @ 0x417330]illegal POC type 15
 [h264 @ 0x417330]sps_id (-1) out of range
 [h264 @ 0x417330]illegal POC type 45871
 [h264 @ 0x417330]illegal POC type 41375
 [h264 @ 0x417330]illegal POC type 23
 [h264 @ 0x417330]slice type too large (6) at 0 0
 picture size invalid (0x80)
 [h264 @ 0x417330]slice type too large (1) at 0 0
 picture size invalid (0x193536)
 picture size invalid (1034736x0)
 [h264 @ 0x417330]sps_id (39) out of range
 picture size invalid (0x256)
 [h264 @ 0x417330]poc_cycle_length overflow 50927
 picture size invalid (21120x0)
 Input #0, h264, from 'video.mov':
 Duration: N/A, bitrate: N/A
 Stream #0.0: Video: h264, yuv420p, 23.98 tb(r)
 Input #1, ac3, from 'audio.mov':
 Duration: 01:45:36.5, bitrate: 575 kb/s
 Stream #1.0: Audio: 0x0000, 48000 Hz, 5:1, 576 kb/s
 Output #0, vob, to 'xmen.vob':
 Stream #0.0: Video: 0x0000, yuv420p, q=2-31, 23.98 tb(c)
 Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 576 kb/s
 Stream mapping:
 Stream #0.0 -> #0.0
 Stream #1.0 -> #0.1
 [vob @ 0x41f380]dimensions not set
 Could not write header for output file #0 (incorrect codec parameters ?)
	I used this tutorial a few month ago to compile ffmpeg :
 http://stephenjungels.com/jungels.net/articles/ffmpeg-howto.html
 Good luck
	I got it to compile, no problem.
 I then extracted an AC3 file and tried playing it. Worked perfectly in VLC.
 I then extracted an h264 file and tried playing it. Worked perfectly in QT.
 Tried putting them in one file and I keep getting "This is not a movie" error message... Hmmm... The plot thickens...
 i use this:
 So, how do I put a HD video with 5.1 into a container thatCode:ffmpeg -i thefile.mkv -vcodec copy -acodec copy output.mp4 ffmpeg -i thefile.mkv -vcodec copy -acodec copy -f mp4 output.mp4 ffmpeg -i thefile.mkv -vcodec copy -acodec copy -f h264 output.mp4 ffmpeg -i thefile.mkv -vcodec copy -acodec copy output.vob I even tried numerous combinations of reordering options (for example): ffmpeg -i video.mov -vcodec copy -i audio.ac3 -acodec copy output.mp4 ffmpeg -vcodec copy -i video.mov -i audio.ac3 -acodec copy output.mp4
 a) is recognized as a video file
 b) is recognized by the PS3?
 p.s. I have mkvtoolnix and perian installed on my system and being a mac user, aac is tightly integrated into my os. Problem is, when I configure ffmpeg, i cannot use the --enable-aac (or whatever it was) and I also cannot install the --enable-gpl. If I manage to get it to accept stuff via ./configure, it fails under make... The only configure options I can set is disable-vhook, disable-sharing enable-mmx. Everything else causes problems.
 Could you please post a direct url to the latest source code release, please. a pkg would be preferred, but I don't think i would be that lucky, now would I?
 p.p.s I think i do have the latest version but the install instructions above state that the libs needed for aac and ac3 come WITH ffmpeg, but it doesn't want to be configured on mine, so yeah...
 When I do a ffmpeg -i file.mkv, it lists the video codec used as being h264 and the audio as being ac3. When I do a ffmpeg -formats, it lists h264 and ac3 in the list, but when i try to add a -f h264 to a command, it tells me it doesn't recognize the codec...
 Any ideas?
	The command to use is :
 ffmpeg -r 23.976 -f h264 -i input.h264 -f ac3 -i input.ac3 -vcodec copy -acodec copy -f vob output.vob
 You can then stream it with a Media Server or rename output.vob to output.mpg to burn it on a DVD-Rw.
	Then tried:[vob @ 0x41f380]dimensions not set
 and still got the same error. By taking out the -f h264, it works but i get a million... wait, let me show you a portion of it:Code:ffmpeg -r 23.976 -f h264 -i video.mov -f ac3 -i audio.ac3 -vcodec copy -acodec copy -s 720x544 -f vob output.vob
 Does this mean that te vob standard does not like having to deal with HD video? If so, apart fro vob, is there another container that I could try?[vob @ 0x41f380]buffer underflow i=1 bufi=2163 size=2304
 [vob @ 0x41f380]buffer underflow i=1 bufi=2160 size=2304
 [vob @ 0x41f380]packet too large, ignoring buffer limits to mux it
 [vob @ 0x41f380]buffer underflow i=1 bufi=2157 size=2304
 I get the mkv file with video encoded with h254 and the file size 4, 6 or 7G . I then try and use that video on ps3 and it gets reported as not recognized file format or corrupted data. I then take the video into ffmpegx and re-encode it using x264 and get a HD video with a file size of 1.0to 1.5G in size. That video the PS3 likes...
 In other words, I don't have to worry about the file being larger than 4G or whatever, I just need it to be inside a container that can recognise it as a video and that the PS3 can use.
 Oh, and finally, that VOB command you gave me earlier... Remember I took out the -f h264 part? Well the video just finished encoding:
 Source video : 1.09G MOV containing only h264 video
 Source Audio: 435M AC3 containing only ac3 video
 OUTPUT: 1.53G VOB that plays audio only
 RENAMED (to mpg): "This movie could not be opened. this file is not a movie file"
 You see my problem, here? Been at it for days now....
 Using ffmpegx I get the videos to encode for ps3 but it takes around 1.5 days on a 2.4G Intel Core 2 Duo and downgrades audio to stereo no matter what. Disabling the "decode using QT" option, it is dramatically faster but the last video I did got to 121% and still didn't start working on the audio, yet... Does this sound strange to anyone other than me?
 So it seems my workflow will have to be this:
 1. Use ffmpegx to encode video from mkv to correct h264
 2. Use ffmpeg to extract audio
 3. [look for settings to enable ffmpeg to join the two into a container]
 -EDIT 1
 I tried using the avi wrapper instead of vob...
 Interestingly enough, by removing everything except the -i and adding only the map option:
 exported h264 video and ac3 audio PLAYS audio and shows black screen
 original video and audio from mkv gives slow moving picture and no audio
 -EDIT 2
 - Okay, so I found I used the Map wrongly and I used the MKV for video AND audio and then included the external audio also and tha is why it had no audio with the slow picture. I then correctly used the map feature to use the ORIGINAL h264 video and external audio and it took HOURS to mux and gave sow video with audio
 - Same command but using encoded x264 video still gives audio but black screen. Any ideas? The command I use is this:
 ffmpeg -sameq -i video.mov -f ac3 -i audio.ac3 -map 0:0 -map 1:0 -vcodec copy -acodec copy output2.avi
  No Audio on PS3 with MultiAVCHDBy Exaile in forum AudioReplies: 5Last Post: 7th Apr 2012, 17:14
  VLC: audio OK, PS3: audio out of syncBy brijazz in forum Video ConversionReplies: 6Last Post: 4th Sep 2011, 01:38
  No audio on avi on PS3By sterankin in forum Newbie / General discussionsReplies: 5Last Post: 18th Jul 2010, 07:38
  Convert MKV with ACC audio to AC3 audio for PS3 playbackBy wolvie77 in forum Video ConversionReplies: 4Last Post: 25th May 2010, 11:13
  1st VOB Audio Fine on PS3, 2,3,4 VOB No Audio on PS3By raerae28 in forum Media Center PC / MediaCentersReplies: 6Last Post: 25th May 2008, 05:10
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
