As well as the price...
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=2525999&Tab=11&NoMapp=
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2700074&body=REVIEWS
Thank you for any info and help..Any recomendations for a nice case and PS too?
never heard of the mobo but it got great reviews from the people that own it so i would say go for it. good prices.
i usually like to stick to name brands on computer stuff. i would get a good quality PSU a good one with stable 12v and enough amps on the 12rail will cost you about 100 maybe less, i have seen them for a little over 50 but im not sure of the qualiy. ive had a few crap PSUs that were cheep go and its not real easy to tell that your PS is acting up till its goes, strange things will happen when starting to fail. and when it does go if you dont know what to look for its hard to know that its bad.
tiger has some good deal on them too though -
check newegg.com .cheaper + they offer free shipping on many items.
this is a better deal/quality IMO
MOBO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131172
CPU,many to choose from,just be sure its retail
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2+50001028+40000343+105172...ame=Socket+AM2
and if you use paypal you will get 20% cashback -
Be aware that you're buying a Dual Core Pentium, which is NOT the same thing as a Core 2 Duo. Not that it's necessarily a bad thing, but core 2 duos are much faster than the dual core pentiums in most benchmarks.
I'm with MJA. His recommended mobo/cpu may be bit more expensive, but an Athalon64 X2 4000+ will blow away that pent D performance-wise (less heat too), and asus mobos among the best, especially for that price.
Edit: Newegg is also top rate, I've gotten several major components from them with no problems.Usually long gone and forgotten
raid 5 -how to rebuild?
By mysts in forum ComputerReplies: 3Last Post: 15th Nov 2009, 21:23 -
New system: Cpu or Gpu transcoding.
By lazylazyjoe in forum Video ConversionReplies: 4Last Post: 10th Oct 2009, 22:01 -
What to do with ISO, trying to rebuild it in DVD RB?
By willhenderson in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2007, 06:02 -
Rebuild Chapters, New VM Commands
By joesphroth in forum Authoring (DVD)Replies: 6Last Post: 9th Nov 2007, 13:26 -
Extract content from damaged DVD and rebuild
By cheerful in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2007, 21:47
