  1. I have used ifoedit to change the aspect ratio in a DVD with a single title ok.
    Is it possible to use ifoedit to create a dvd that has 2 titles with different aspect ratios, one title that is 4:3 and one title that is 16:9?
    For example, I have an authored DVD that has 2 titles, both are flagged as 4:3. One of the titles is incorrect and needs to be changed to 16:9 and the other title is correct at 4:3.
    I want to end up with a dvd with 2 titles, one 16:9 and one 4:3.
    When I open up the ifo file, I only see one place to change the video aspect ratio:
    "Video: MPEG2 .......................... (4:3) ................"
    Does this mean that when making an aspect ratio change using ifoedit, it applies globally to all titles in the dvd?
    Oct 2005
    666th portal
    they have to be in different titlesets. each VTSxxx_xx.IFO contains a aspect ratio descriptor.
