sir,
how can i reduce the quality of a dvd file?
suppose i have a dvd with aroung 7 GB.the ocntent is only one movie.
i want ot reduce the quality so that i can fit two movies in a single layer disk.
thorugh wchich programme i can do that?
In dvd lab , i have created a menu.
first i made the background,then a frame then buttons were added. then i named the butn with the name of the clips.then link was stablished. but when the button number came it show not the order in whicih i entered the name of the vidoe files.i linked the file in one two three ...order. where as the butn number shows 1,3,4,5,2
why this happen?
thanks
dvd shrink....then dvdshrink again....but it'll look pretty poor. cant recommend it.
you might consider turning the films into Divx files, if you have a player that supports Divx, which many do nowadays... for that, try autoGKnever absorb anything bigger than your own head -
kindly tell me how can i convert the vob into a divx file? and then what to do with the divx file ,plz suggest the softwre i need for the same.
thankz -
If its a keeper, why not reencode it (and still keep it as proper DVD)?
Just look up the guides on the left pane
Dvd reauthoring
By Psco2007 in forum Authoring (DVD)Replies: 6Last Post: 23rd Sep 2011, 12:41 -
DVD Reauthoring - Removing a menu
By xDarKnighTx in forum Authoring (DVD)Replies: 2Last Post: 2nd Jul 2010, 00:32 -
reauthoring a DVD
By jaime007 in forum ffmpegX general discussionReplies: 2Last Post: 5th Apr 2009, 12:54 -
DVD reauthoring
By Meagain in forum Authoring (DVD)Replies: 10Last Post: 28th Dec 2008, 20:22 -
DVD Decompiler for reauthoring
By Drakul in forum Authoring (DVD)Replies: 0Last Post: 18th Aug 2007, 17:09
