I am using Windows XP Professional SP2. While I am playing DVD using VLC Media Player, it is playing the DVD with no problem but the same cannot be played using Windows Media Player. The Media Player only showing the pictures but no sound. Anybody faced such problem? How to Fix it?
My sound device is AC97 (onboard).
regards
anindyanuri
It may have AC3 audio and you don't have that codec installed. VLC has it's own codecs, so it plays most anything. You could drop one of the VOB files into Gspot 2.70 and it will tell you what codecs you need to play the audio. AC3 Filter should work for decoding if that's what you're missing.
VLC....as was suggested above....
or see hear,
http://www.microsoft.com/downloads/details.aspx?FamilyID=DE1491AC-0AB6-4990-943D-627E6...n&Hash=RQY5N8C" Who needs Google, my wife knows everything" -
Yes, there was no Media Player compatible mpeg2 decoder installed in my system, which caused the problem. I have installed a GNU GPL supported mpeg2 decoder which is Media Player compatible, which solved the problem.
regards
anindyanuri
VLC was previously installed in my Windows XP system. Now after comparing Windows Media Player and VLC, I feel that VLC is giving me better quality than Windows Media Player while playing the DVD.
regards
anindyanuri
mp3 plays on Windows Media Player but won't play last minute in Sound Forge
By wetcamelfood in forum AudioReplies: 2Last Post: 1st Dec 2010, 16:47 -
Windows Media Player: MPG playback bar moves faster than video plays
By Grunberg in forum Newbie / General discussionsReplies: 4Last Post: 15th Sep 2009, 05:07 -
MPEG2 file plays in windows media player but not properly in premier cs3
By ibanezfreak in forum EditingReplies: 1Last Post: 20th Oct 2008, 04:42 -
No Sound on DVD Created From Hauppauge HVR-1600 in Windows Media Player
By JimBarbasol in forum Capturing and VCRReplies: 11Last Post: 18th Jan 2008, 23:02 -
DVD Audio Plays On DVD Software But Not On Windows Media Player 11
By CurtisMinBC in forum AudioReplies: 2Last Post: 29th Jun 2007, 13:39
