Guys,
I grabbed one of those players and was wondering if anybody had luck running a USB hub on it? I tried one powered hub and it didnt work. It didnt see any device plugged in, that it otherwise saw..
Any experience?
Cheers
Matt
The USB feature is the best I have ever seen on a player![]()
Stand alone players are only capable of communicating with a single storage device over USB. They have a basic driver set only capable or recognizing and communicating with storage devices that meet a specific criteria. You're not the first person to try, and I've never seen one that worked.
Google is your Friend -
Thats what I thought ...
I wanted to install a back USB port into my 5982 as the cable in the front looks ugly...
I could just connect a USB port in parallel to the exisitnt one and then only use one at a time but it would have been nicer to run the one port of the player into a HUB (in the inside) and then run one port from the hub to the front and back ..
cheers
Matt
Philips DVP5982/37 USB file question
By kme06d in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Jun 2011, 17:09 -
Philips DVP5982 Compatible USB Flash Drives
By Nikephoros in forum DVD & Blu-ray PlayersReplies: 22Last Post: 20th Mar 2009, 00:34 -
Philips DVP5982 USB FYI
By 403gl in forum DVD & Blu-ray PlayersReplies: 5Last Post: 1st May 2008, 07:53 -
Philips DVP5982 - USB hard drive folders not all showing
By PunkHippie in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Sep 2007, 12:58 -
Philips DVP5982 USB & StaxRip
By Trac in forum DVD & Blu-ray PlayersReplies: 10Last Post: 17th Sep 2007, 11:20
