So I've got my 8mm camcorder capture rig going and have only one tape that's caused me any trouble. It was fillmed on a Sony 8mm camcorder about 6 years ago, and during playback it goes to blue screen every few seconds for about 3 seconds. It's like 5 seconds of playback, 3 seconds of bluescreen, repeat. Most of the time you can still hear audio playback during bluescreen.
Funny thing is that most of this tape is fine, it's just one 10 minute clip at the end that's doing this.
I've cleaned the heads to no avail. Any ideas?
Results 1 to 10 of 10
Best try a different 8mm deck. Its likely a tracking issue that your existing player can't resolve....
It isn't the camcorder or tape that is going to blue screen, but the monitor or capture device that is receiving the feed. Most units will go to blue screen if they lose sync pulses, you ideally need something that doesn't and displays what it is actually receiving. At least then you would know what the problem is.
It actually could be the camcorder producing the blue screen when the tracking issue becomes too severe. Check your camcorder settings and you may be able to turn this feature off. I have several VCRs that do the same thing.
First is to determine where the source of the blue screen is, does it do this if you hook it directly to a TV?
Signal is unstable. Could be anything from bad tape to bad wires. But the transmission is somehow incomplete.
Same Question = Is the blue screen on your capture computer monitor or on the TV screen ?Originally Posted by thecoalman
It's the camcorder itself giving the blue screen right on it's LCD display. I'm guessing it's tracking... I'll try to dig around with family - someone probably has an 8mm camcorder collecting dust somewhere!!
Playing the tape on the camcorder only shows a blue screen.
By seven1970 in forum Capturing and VCRReplies: 9Last Post: 23rd Mar 2012, 18:44 -
From 8mm tape to Final Cut...no camcorder
By cecile in forum Capturing and VCRReplies: 18Last Post: 23rd Aug 2011, 23:53 -
Will a Digital 8 camcorder read 8mm tape?
By Tenacguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Jun 2009, 14:24 -
8mm camcorder tape playback suggestions?
By Bix in forum RestorationReplies: 8Last Post: 23rd Aug 2008, 02:02 -
Capturing the blue screen with white DV tape graphic
By fusiblelinks in forum Newbie / General discussionsReplies: 5Last Post: 27th Jun 2007, 22:33
