Hi Everyone,
I was given a series of dvd's with adhesive labels on them. Each dvd contains a program that will be shown on local public access cable tv once I solve the following problem. When I submitted the first one the executive director said their conversion/transcoding machine can't handle dvd's with labels. He wants me to give him the programs on new dvds without the label. I've never copied/cloned or replicated a dvd before bit for bit.
Here's where I need advice.
I need to preserve original quality and duplicate each dvd exactly. In regards to potentially involving copyright protection I doubt it has much if any although I will check with the source.
What is the best way or application that will achieve the above that's fairly easy, reliable & gets the job done right the 1st time? Is there a no-brainer solution? All I need to do is copy.. that's it!! What do you successfully use?
Looking forward to your suggestions and reccomendations.
Thanks in advance.
Bruce
First make a folder with a name you will correlate with the proper DVD an add ISO to the name like: WHATEVERDVD_ISO.
1. Then use DVD Decryptor in MODE --> ISO --> READ, to make an ISO/MDS file. (click on the little folder icon to put it in the folder you made.)
2. When that's done, open imgburn 2 and switch to write mode. Then open the mds file made from step 1 and create the DVD.
This is what I would do. Other programs like Nero should do it to if there's no copy protection. -
Thanks so much for the step by step mini guide.
I'll try it very soon and respond.
To the forum, if there are other options I'm also glad to hear about those to.
Bruce -
You can also remove the labels. I done this in the past using WD40. Just soak the label with WD40, let it sit about an hour, and the label should peel right off. Then just clean the disc with alcohol and/or warm soap and water.
Google is your Friend
Can't clone DVD with CloneDVD2
By Navop in forum DVD RippingReplies: 4Last Post: 6th Mar 2012, 12:36 -
Best & easiest way to clone a dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 30th Jul 2010, 10:00 -
How tp properly clone a DVD using Toast 10
By Jabroni4872 in forum MacReplies: 2Last Post: 28th Apr 2009, 09:25 -
clone dvd 2
By fitos in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 18:16 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03
