i had downloaded some videos. when i view it using my laptop,the quality is good. however, after i have burned it into cd-r, there is a problem with the sound system( the annoying sound that come out when your vcd is being scratched). when i was trying to save the video as avi with virtualdub, there is a box popped out saying that, there is no output node in audio filter graph
the original video file before i converted it to mpeg.
General #0
Complete name : C:\Downloads\Totally Spies\Season 1\totally spies 101 a thing for musicians [dummy].avi
Format : AVI
Format/Family : RIFF
File size : 169 MiB
PlayTime : 21mn 24s
Bit rate : 1096 Kbps
StreamSize : 1.90 MiB
Writing library : VirtualDub build 18160/release
Video #0
Codec : XviD
Codec/Family : MPEG-4
Codec/Info : XviD project
Codec profile : Streaming Video Profile/Level 1
Codec settings/Packe : Yes
Codec settings/BVOP : Yes
Codec settings/QPel : No
Codec settings/GMC : 0
Codec settings/Matri : Default
PlayTime : 21mn 24s
Bit rate : 963 Kbps
Width : 640 pixels
Height : 480 pixels
Display Aspect ratio : 4/3
Frame rate : 23.867 fps
Resolution : 8 bits
Chroma : 4:2:0
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.130
StreamSize : 147 MiB
Audio #0
Codec : MPEG-1 Audio layer 3
Codec profile : Joint stereo
PlayTime : 21mn 24s
Bit rate : 126 Kbps
Bit rate mode : CBR
Channel(s) : 2 channels
Sampling rate : 48 KHz
Resolution : 16 bits
StreamSize : 19.4 MiB
Writing library : Xing (new)
after being converted to mpeg
General #0
Complete name : D:\season 1\totally spies 101 a thing for musicians [dummy].mpg
Format : MPEG-1 Program
Format/Family : MPEG-1
File size : 213 MiB
PlayTime : 21mn 24s
Bit rate : 1391 Kbps
Video #0
Codec : MPEG-1 Video
Codec settings/Matri : Standard
PlayTime : 1s 1ms
Bit rate : 1150 Kbps
Bit rate mode : CBR
Width : 352 pixels
Height : 240 pixels
Display Aspect ratio : 1.467
Frame rate : 29.970 fps
Bits/(Pixel*Frame) : 0.454
Audio #0
Codec : MPEG-1 Audio layer 2
PlayTime : 21mn 24s
Bit rate : 224 Kbps
Bit rate mode : CBR
Channel(s) : 1 channel
Sampling rate : 44 KHz
Video0 delay : -21mn 23s
after being burned into cd-r
General #0
Complete name : E:\MPEGAV\AVSEQ01.DAT
Format : CD Mode 2 / / CDXA/MPEG-1PS
File size : 219 MiB
PlayTime : 21mn 24s
Bit rate : 1429 Kbps
Writing library : Created by Nero
Video #0
PlayTime : 21mn 23s
Bit rate : 1100 Kbps
Bit rate mode : CBR
Width : 352 pixels
Height : 240 pixels
Bits/(Pixel*Frame) : 0.434
Audio #0
PlayTime : 21mn 24s
Bit rate : 224 Kbps
Bit rate mode : CBR
Video0 delay : -33ms
is there any way to solve this problem? thnx...
[/b]
Closed Thread
How does a scratched VCD sound?
No matter, downloaded TV series is warez according to site rules.
/MatsOriginally Posted by Rules
Which would produce the best quality?
By langham in forum Video ConversionReplies: 4Last Post: 17th Apr 2011, 12:32 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
What AVI would produce a 2:1 ratio?
By lordsmurf in forum Newbie / General discussionsReplies: 8Last Post: 7th Jul 2010, 02:18 -
How to produce like this effect in After Effects?
By 3thman in forum EditingReplies: 6Last Post: 5th May 2010, 19:54 -
WMP 11 can play video file and but produce distorted sound at 48Khz
By hulinning in forum Software PlayingReplies: 1Last Post: 13th Nov 2009, 21:02
