  1. Hello, I have the following Rig:
    Intel Core2 Duo 6600 @2.4GHZ
    ASUS GeForce 7950GT 512MB
    ASUS P5B-E (Intel P965chip set)
    2GB DDR-2 800MHZ HyperX Kingston
    Sound Blaster live 5.1!
    Windows XP Pro SP2
    What frames per sec should I expect from Crysis (Full Game, not demo) at High details, DX9 & 1280 x 1024?
    Thanks in advance.
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    You can use this and see if it will run it..
    http://www.systemrequirementslab.com/referrer/srtest
  3. So, I just fired up Crysis.
    The game detects optimum settings for my rig and sets everything to high @ 1024x768 Res and no 0xAA.
    But the in-game frame rate is quite laggy, so I lowered the shadows to Low and Post processing to Medium @ 800x600, no 0xAA.
    After these changes take place, for the most part the in-game frame rate seems to be fine with only a few slow downs in some intense fight scenes.
    Strangely enough some of the cut-scenes still seem to be laggy.
    I hadn't had time to run the in-game benchmark to get some precise FPS, I'll try it later and post my findings tomorrow
    I did notice a bug where the sand next to the sea water in corrupted and full of large square pixels. A patch or newer nvidia driver should fix that!
    Overall in DX9 & WinXP, the graphics, gameplay and theme, are just too similar to Far Cry which I was not too fond of.
    It doesn't seem to be that much of an improvement and can't really say I'm impressed so far.
