I have an IMG file of a film and I'm trying to make a DVD that will play in any DVD player.
I have 2 DVD recorders:
Internal HP 1040
External Buslink DVD R/RW
XP Home
Software: Nero 8 Ultra, Slysoft Clone/AnyDVD
Media: DVD-R, DVD+DL, DVD+RW
I found several recommendations online that said to rename the iso to an img and then burn it with Nero. Nero didn't like the DVD-R but was happy to brune with a DVD +DL. The problem is that the DVD plays just fine on the drive it was burned on (and yes, it was finalized) but if I try to play the DVD in a regular DVD player, the player says the file is no good.
I've also tried burning the ISO file to DVD via AnyDVD and CloneDVD with a DVD-R. After an 8 minute 'writing' process, I then was told it was done but then again, the DVD player says the DVD is unplayable.
Can anyone recommend what to do? I'd hate to have to 'rip' the DVD I created to AVI and then put it back to DVD (a process that DOES work for me). I'm afraid of degradation to the file.
Any help is much appreciated!
not sure why they would tell you to rename...Just use IMGBurn in write mode..
And what media type are you using?
http://forum.imgburn.com/index.php?showtopic=61" Who needs Google, my wife knows everything" -
IMGBurn is your friend. Download and play with it - you'll be pleased with what it can do. The more that I use it, the more I'm impressed.
Never forget: IMGBurn was created by LightningUK, the founder of DVDDecrypter.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
I think we're missing some important details here.
How big is that ISO file?Want my help? Ask here! (not via PM!)
"Won't play" as in "Spits out the disk"?
"Won't play" as in "Doesn't seem to think there's a disk there at all"?
"Won't play" as in "Displays some error message"? (What message in this case?)
/Mats -
Talk about an understatementOriginally Posted by lordsmurf
Are you sure the image is of a standard DVD file structure ??
What dvd player are you trying to play the burned dvdr on ??
Open one of the VOB's from a burned disc with Gspot, AVIcodec, and see what the framerate, resolution, ect is.....
You may be burning a PAL dvd image in which case your dvd player/tv may not play PAL material, seeing as you are listed as an NTSC country.....
In which case... you may be converting to NTSC from PAL by ripping, converting to AVI, then converting back to NTSC..........Originally Posted by digitalred93
You have pretty much given NO actual info on the IMG you are trying to burn, what is contained in the IMG file, or the hardware in which you are trying to play it on.............
An img, or ISO file can contain ANY file or video/audio/photo info... it is just a container, like a zip or winrar container.....
Obviously from people that are totally clueless to how these format's actually work.......Originally Posted by digitalred93
Converting ISO/IMG to AVI: How to choose the desire audio track ???
By htp367 in forum Video ConversionReplies: 3Last Post: 19th Jul 2009, 12:11 -
.iso, .img, .cue, etc. to DVD
By Xandal in forum ComputerReplies: 5Last Post: 26th Aug 2008, 11:52 -
Problem with .IMG/.ISO file
By macamba in forum Newbie / General discussionsReplies: 6Last Post: 6th Jul 2008, 03:57 -
Which is best to burn - img, iso or video_ts
By dynamique in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2007, 14:13 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
