Received Pioneer DVR-450h-s as a gift. It works great. I was just wondering if it was possible to add a DV input port to transfer camcorder movies. If yes, can you let me know how?
Thx
	If it doesn't have a 1394A port, you can't add one as the internal parts that make it work would be missing, along with the firmware to use it.
	To clarify, when you mean the internal parts, are you referring to the actual interfaces or the board conections? If it's the interfaces, they are readily available. However, if they can't connect to anything, I guess there is no hope!!!
 Thanks again...
	I don't know it for a fact, but I suspect the integrated circuits and associated electronic parts that would be needed for that type of conversion wouldn't have been installed on the circuit board.
  Pioneer DVR-520H video to PC using the DV-Out port - no disc burning.By PuzZLeR in forum DVD & Blu-ray RecordersReplies: 14Last Post: 27th May 2021, 15:26
  Problems connecting a laptop through the SVideo port to a Display VGA inputBy jeproca in forum Newbie / General discussionsReplies: 21Last Post: 4th Nov 2010, 10:31
  Sony HDR-FX1 firewire-input-portBy stompinne in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 25th Feb 2008, 15:23
  Buying a new DVR/HDD unit- thoughts?By JoeDirtGR in forum DVD & Blu-ray RecordersReplies: 2Last Post: 31st Dec 2007, 05:40
  Pioneer DVR-545HX-S with USB portBy MOPLASMA in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Oct 2007, 08:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
